05-29-2022, 02:32 PM | #1 |
Rep 10
Mhd stage 2+ e20 dissapointing results
So long story short, i have 435i 6mt ewg running mhd stage 2+ e20 with walbro 450 lpf, decat, turbosmart bov, ftp intake(charge pipe, boost, inlet), wagner ic upgrade, running on 305/30/r20 potenza s007 at 1.7 bar, rear bc zr coilovers on softest dampening (low speed and high speed compression on factory settings cause i just dont know how to set them up yet so havent touched those knobs)
seems a bit dissapointing results ambient temp was 10 degrees celsius, elevation from sealevel 57 meters any pointers to what would be causing low boost on first gear would be much appreciated and how to get this car running faster, got beaten by e90 335i pwg 98ron, only intake, 265/35/r19, custom flash, no other mods https://datazap.me/u/haleskinn/435i?log=0&data=4-18 |
06-05-2022, 11:32 PM | #2 | |
Check out my Youtube @n55david!
1302
Rep 3,551
Drives: 2017 m240i, 2015 X3 x35i
Post just the 1/4mile run so I can see all the info thejeremyman9 can you look at this log and tell him how to do a proper log...
2017 m240i xDrive 10.67@132.32mph w/bm3
2015 335i xDrive 10.95@124.99mph w/bm3 - SOLD 2015 X3 x35i pwg 12.96 catless w/bm3 stage 2 93 ots IG: @n55david For pics and updates! Youtube: @ n55david For videos or Racing etc |
FlorinQCK-2.50 |
07-04-2022, 08:53 AM | #3 |
Rep 4,203
Post this in the main engine drivetrain forum - but immediately noticeable - your timing terrie because your IC is very very bad - at one point you’re at 69C - which is 156F. That’s horrible.
FlorinQCK-2.50 Pussiwillow522.00 |
12-02-2022, 11:50 AM | #4 |
Rep 239
Drives: '17 M240i 6MT
What kind of launches procedure are you doing? That 0-100 isn't particularly inspiring. That could be eating away at your overall times a bit. The rest, I can't speak on.
12-16-2022, 08:54 AM | #5 |
Rep 10
yeah, i did some more runs after that i even capped at 84c IC, replaced the ic with do88.se one, wot cant even get more than 35-36c now
12-16-2022, 08:55 AM | #6 |
Rep 10
manual launch procedure with clutch and gas pedal, also i figured out one problem, i was having too much wheel hop, now the 0-100 should be better, but that we will only know after the snow has melted
