F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > UK > Polish recommendations
ARMA SPEED
      04-30-2024, 01:13 AM   #1
Mcdaddy
Drives: Bmw 330d xdrive
Hi
I have ended up with a number of marks on the bonnet from bird crap. I have tried some Ag paint restorer on it using an orbital polisher but they have not removed fully.
Can anyone recommend some decent polish that will likely remove them?
Thanks
      04-30-2024, 02:40 AM   #2
TurboWeasel
Drives: BMW 330D
I use Farcela G360 compound for stubborn stuff. You can give that a go.
      04-30-2024, 03:23 AM   #3
danb1979
Idiotic lifter of heavy stones...
danb1979's Avatar
2015
Drives: 2015 F31 325D M Sport touring
Koch Chemie 6.01 - used it on my F31 the other day; bonnet came up superb
https://www.amazon.co.uk/Koch-Chemie...%2C108&sr=8-10
But I'd recommend this first to see if it'll cut through the damage:
https://www.amazon.co.uk/Koch-Heavy-...s%2C108&sr=8-4
My car: 2015 F31 325D M Sport Touring in Glacier Metallic Silver - Keeping it OEM 'Plus'
Project: https://f30.bimmerpost.com/forums/sh....php?t=1982298
      04-30-2024, 03:26 AM   #4
Blacktemplar
Blacktemplar's Avatar
Ukraine
3488
Drives: X3 M40i
Bilt Hamber Cleanser Polisher is pretty good, but it sounds like you might have damaged the clear coat. Maybe try Meguair's Ultimate compound. I see you're on Merseyside - seagull shite down that way is nasty corrosive stuff!
Might need a detailer to do a deeper paint correction if it's eaten through to the paint.
      04-30-2024, 10:19 AM   #5
PG325
Drives: BMW e30 325i & f32 435i
Bird etching can sometimes be removed by heating the panel, check out Youtube
      04-30-2024, 02:39 PM   #6
Allworth
Drives: X1 xDrive20d (E84)
T-CUT
1995 E34 525td auto • 2016 F30 320ed auto
      04-30-2024, 05:25 PM   #7
un1eash
Drives: M235i
AG paint renovator can be quite harsh as it has a lot of cut. I use Meguiars 105 for paint correction and 205 for final polish.
      05-01-2024, 01:44 AM   #8
NotGotABimmer23
Drives: 340i touring - incoming
Meguires ultimate compound on a DA is good, BMW paint is pretty hard so need some decent cut.
      05-01-2024, 02:12 AM   #9
Alscoob
Alscoob's Avatar
Drives: G31 540i M Sport Edition
My go to polishes.... https://www.poorboysworld.co.uk/collections/polish
I would use the SSR-2.5 to start with if that isn't good enough use the SSR-3 but although the polish breaks down to a finer & finer polish would use the SSR-1 to finish the job if you have used the SSR-3
... you will need dual action machine polisher for these and some of the other polishes mentioned above. While you can apply by hand they are designed for machine application so consider it carefully.
IPA wipe down after then seal paint with EX-P sealant bling!
danb19792015.00
      05-01-2024, 06:21 AM   #10
YODI
Drives: 2019 F31 320d M Sport
Put a close-up photo up, no matter what you use it may not get rid of it depending on how bad it is but you may be able to wet sand it and then polish it.
Post a pic I'll let you know
f30post
