F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > UK > Idrive/Cluster Clock not keeping time
ARMA SPEED
      10-25-2019, 12:35 PM   #1
A22-JAM
A22-JAM's Avatar
Scotland
Drives: F32 435i Coupe Black
Question Idrive/Cluster Clock not keeping time
Hello Everyone,
New to the forum. Recently bought a new to me F32 435i. Loving the car but it has one (hopefully) small problem with the clock. Sorry this will probably end up long winded but basically it won't keep time. I can go into settings update the time to the correct time using the automatic option or manually but it won't change time afterwards. For example - if i update the time at 12:00 midday it will show 12:00 on the iDrive and also the cluster but it wont change from that. Soon as I go into update it again it'll update to the correct time but same problem again it remains at it. I took it to my local BMW dealer and they want to charge 1.5 hours labour hours which is £156 to do a programming session and if it takes longer than the time the price will go up further! They did check versions and I have the most up to date version. Any help from anyone or ideas to try please let me know. Even if you know someone in the Aberdeen area that could have a look at a better price it would be hugely appreciated.
Jason
      10-28-2019, 08:41 AM   #2
WillLowe
Drives: F32 435d
Sounds like a coding issue usually when the cluster or head unit has been changed. Grab someone with Bimmercode and try Code HU_NBT => KOMBI_CIC = kombi_high.
      10-28-2019, 08:46 AM   #3
xenon
xenon's Avatar
England
1405
Drives: 2021 G21 330i M-Sport
It is a known, but uncommon, bug. If you search these forums there was a thread on it a while back. If I recall correctly - and I may not be - the solution was a new NBT unit, as ridiculous as that sounds. It wasn't coding.
EDIT - I didn't recall correctly - you'll be pleased to hear the fix is much cheaper. Free in fact if you have a 13mm spanner...
See here:
https://f30.bimmerpost.com/forums/sh...ighlight=clock
Ian
Current: 2021 G21 330i M-Sport
Previous: 2018 A6 Avant S-Line MMI+, 2014 F31 320d M-Sport, 2013 F10 520d M-Sport, 2011 F10 530d M-Sport, 2008 320i M-Sport Coupe, 2002 325i, 2001 318i valvetronic, 1998 318i, 1996 525i, 1990 Porsche 944S2
Wills28698.00
      10-28-2019, 01:59 PM   #4
Hooded
England
1669
Drives: F30 330d M-Sport
Yes I’ve read somewhere before that disconnecting the battery for 45 minutes seems to fix this issue if you are unlucky enough to have it.
      10-28-2019, 04:50 PM   #5
A22-JAM
A22-JAM's Avatar
Scotland
Thanks everyone. I honestly thought i'd searched every possible combination of keywords and that thread never appeared. Will try disconnecting the battery tomorrow. If it doesnt work how difficult is coding using bimmercode? I have the Vgate OBD connector and the app downloaded but I only planned for doing basic coding. Or worst case scenario how much does a new NBT unit?
Thanks again for the help
      10-30-2019, 02:53 PM   #6
A22-JAM
A22-JAM's Avatar
Scotland
Talking
Just an update on this. Removed the battery negative terminal today and left for 45 minutes and refitted. Complete success, clock now keeps time perfectly
Cheers for the help and can't tell you how glad I am that it was an easy fix.
Side note:
To anyone who gets this problem and tries this solution don't be an idiot like me and close the boot while the terminal is off. Absolute tool for that moment of madness!!!
      05-01-2024, 10:05 AM   #7
CraigD
Drives: BMW M4 F82
THANK YOU
Can't tell you how happy I was to finally find this thread - been trying to resolve this for a year - every search turns up nothing - spoke to BMW - was told to replace the whole cluster - nonsense! Spoke to BMW specialists who never heard of it before - anyways finally found this thread - 45 mins disconnected and it working like a charm - thanks to you all on this thread, feels like I have a new car again
      05-01-2024, 10:07 AM   #8
CraigD
Drives: BMW M4 F82
AND - make sure you release the backseats (M4) or put a towel over the lock so it doesn't get closed - my better half thought she was doing me a favour when she came home and saw my boot open - she closed it I had to research 'Opening an M4 boot whilst the battery is flat....
f30post
