04-11-2018, 05:11 AM | #23 | |||
Rep 32,881
LobB5109.00 |
08-09-2018, 05:59 PM | #24 |
Rep 32
I have the same problem. Does anyone know what in my system could be preventing the launcher to open? It is a windows 7 x64 (just reinstalled/formatted) with framework 4.7
08-16-2018, 07:47 AM | #25 |
Rep 44
08-16-2018, 08:08 AM | #26 | |
Rep 44
https://www.bimmerfest.com/forums/sh...&postcount=603 |
09-07-2018, 12:47 PM | #27 | |
Rep 32
09-07-2018, 01:18 PM | #28 | ||
Rep 32,881
LobB5109.00 |
09-07-2018, 01:46 PM | #29 |
Rep 32
09-08-2018, 11:00 AM | #30 |
Rep 32
09-15-2018, 09:35 AM | #32 |
Rep 10
Hi everyone, specially Shawn whose name I have seen everywhere I have been on bimmerpost.
I am fairly new to ESYS and am currently coding adaptive headlight driver modules both sides. I have made some progress but frankly failed to get it working. This F30 RHD 2014 came with adaptive from factory. Needed replacement headlights and driver modules. Starting off the first issue I ran into was getting the CAFD (cafd_00000794_017_068_102) file under FEM, it was non existant. So did a detect CAF and generated the cafd (which was slightly different the last number is 101 instead of 102). Now when I edit FDL under FEM I don't get the name of the MODULES in the daten list. And search result is nil. So havent been able to code the headlight driver modules on this f30. Any help would be greatly appreciated. |
09-17-2018, 05:57 AM | #33 |
Rep 1,455
I can't help specifically with this but have you checked you have the latest psdzdata files ?
Shawn will provide a link if you need one and I've always found him extremely helpful as long as you've made an effort to eliminate anything silly and provide him with all pertinent information |
LobB5109.00 |
09-17-2018, 10:14 AM | #34 |
Rep 10
I have been able to sort that problem out as well. I think I needed the Token master premium launcher.
Unfortunately couldn't get to the bottom of my problem with the TMS driver modules. I have coding error fault code even though I VO coded out 524 and coded it back in. As soon as I do that the fault codes reappear. So I have for now totally removed the adaptive headlights option from the car. Don't see the adaptive headlights failure light anymore. I am not sure though if the lights will be working fine as they are originally adaptives. Everything turns on. |
11-03-2018, 12:05 AM | #35 | |
Rep 5
but frist,you want to read to the ECU, and then the ECU list appears ELE TMS or FLE TMS. Select ELE, and then detect CAF for swe. then finsing job. good luck. |
01-03-2019, 06:06 PM | #38 |
Rep 1,141
01-04-2019, 02:39 AM | #39 |
Rep 277
01-04-2019, 02:13 PM | #40 | |
Rep 1,141
It's Win 10 1809 Build 17763.134 (the latest current build) that is known to have issues. I had to update to one of the later insider builds (18290) to get E-Sys working again. |
LobB5109.00 |
01-05-2019, 06:08 AM | #41 | |
Rep 1,141
Just tested on my diagnostic laptop, and had the same issue. After reading this: https://f30.bimmerpost.com/forums/sh....php?t=1457494 I changed the system date to 16/06/2018, ran the .BAT file, and everything is working again. |
01-05-2019, 06:15 AM | #42 | |
Rep 1,525
01-05-2019, 08:45 AM | #43 |
Rep 1,141
01-05-2019, 06:01 PM | #44 | |
Rep 2,399
ive changed my date to 15.06.2018 successfully ran the BAT file as admin tried to launch esys launcher but it still doesnt open? any ideas? |
