F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > Andream MMI Box - Wireless CarPlay & Android Auto
ARMA SPEED
      05-05-2024, 01:06 PM   #13113
minulache
Drives: BMW 4 F36 & E92 N55 LCI
Originally Posted by BMWChap View Post
You're right about the firmware, my guess is that it's their modified version so I wont be doing any updates as i'm already unimpressed with this unit, updating my brick it. .... would still like to get YouTube working though
So even with that firmware that you have Airplay does not work?
You have everything like me, except the Cust Version. I asked already Andream to see if they have any updates. In case they give me some updates for CIC, I will attach them here so you can also use them. I am pretty sure you also have the Andream Version.
      05-05-2024, 01:15 PM   #13114
Coderedpl
Coderedpl's Avatar
Drives: F80 M3
Originally Posted by fe7565 View Post
Nice write up!
I use CarPlay, but some of these may apply universally or to AA...
For steering wheel control scroll, try to code (Bimmercode expert or other).
These are CIC and NBT, so if you have NBT EVO use the equivalent codes:
BASIS_KOMBI_MMI_LIST = aktiv
or...
HU_NBT > KOMBI_CIC > kombi_low
and MMI_List > aktiv
Phone call issues:
Make sure that in the phone Bluetooth settings the device is set to "car speaker" and that you have given the myriad of permissions that Android requires for BLE and wifi connections.
If no go: try to delete all BLE connections from car and MMI and phone and re-pair all of them again ( I know it's a pain)
If no go: then may want to try to use only BLE between the phone and the MMI only...or the phone and the car only (do not see much benefit).
The MMI seems to boot up at times a fraction later than the HU. This causes an internal CID bus error that you cannot see unless you use ISTA+, but you can ignore it. But this is also happening when powering off the HU and the MMI. That's when you see the "No Signal" in the CID. This is something that short of a hardware solution the Chinese manufacturer should be fixing via coding.
I tried using YouTube but could not set it up. Gave up after a couple of tries since it's not a priority. How did you get yours working?
Yes, as long as you are in BLE range of the car with your phone, it will want to stay connected or may reconnect.
At times, if you go out of BLE range, and then return about 10-20 mins later (assuming that the HU did not yet go to sleep) the MMI will not reconnect to my phone via BLE. May be 1 out of 10 times. I have to press BACK button for 3+ secs to reboot MMI and then it reconnects 19 out of 20 times. If that does not work, I may have to delete the phone to MMI BLE link and re-pair again.
I think you must have read my post way too quick.
1. My steering wheel controls work just fine on the car, there is no need for me to code anything, as seen by others, it simply doesn't seem to work with the Android Auto mmi box.
2. I do not have any bluetooth issues.
3. YouTube I never attempted to use, just made an observation that it will likely want to use the AUX instead of the car Bluetooth. I have no desire in loosing audio quality just to use YouTube via the MMI-Box, I'll have alternatives if I need them.
Considering the box interfaces with the car, stays on and boots after some time, if you have this installed you WILL see codes in the HU_NBT portion when car is scanned, again, not the end of the world. Just something to keep in mind.
      05-05-2024, 02:33 PM   #13115
BMWChap
Drives: F32
Is there another way to test AirPlay ?, just so I can rule out if it’s YouTube.. and I’m sure this unit is Andream and I’m hoping that German ModsUK sends out updates to all their customers when they’re released
      05-05-2024, 04:36 PM   #13116
minulache
You just need to connect an iPhone device in the AirPlay menu of the MMI. Also, it says that you have to unselect "Use car's bt phone something" in the setup. I tried today with 3 iPhones, 15 Pro Max, 12 Pro and XR and none of them work so curious to see what Andream says about this.
Regarding your problem, you should send a message to ModsUK to assist you with the updates
      05-06-2024, 03:36 PM   #13117
PinkGuy
Drives: 330e 2016
Anyone knows where to get the Andream for NBT systems? Im located in Norway and cant seem to find it on AliExpress. Did however find a Andream website, and they also claim to have EU warehouses: https://www.andream-eu.com/product/ewm-bmcp/
Does anyone have any experience with this website?
      05-07-2024, 12:40 PM   #13118
minulache
Originally Posted by hagncola View Post
Firmware issue, you need 1.6.16_R2 -- than should work.
Did this update and still doesn't work. Maybe I need a new MCU Vers? Can someone help me with the latest one, please?
I ordered from there and it was good.
      05-08-2024, 02:25 AM   #13119
hagncola
Drives: BMW F20 (12/2018)
Did you try, disable Wifi and Bluetooth on the phone if carplay is connected, afterwards activate Airplay on the MMI and afterwards enable Wifi only on the phone and check if connected by wifi to the mmi box. If connected enable mirroring/airplay on the device.
      05-08-2024, 03:45 AM   #13120
minulache
Yes, I even deleted the Carplay connection for the MMI and phone just to be sure that Carplay doesn't affect in any way the Airplay.
      05-08-2024, 04:53 AM   #13121
minulache
So I just received and answer from Andream. Apparently, the Airplay function doesn't work with iOS 17
      05-09-2024, 01:46 AM   #13122
hagncola
Strange, BMW EVO ID6 with Roadtop MMI Firmware ER1.76R2 and VW Golf with Andream MMI FW 1.6.16R1.
Airplay with iPhone 13 and iPhone 15pro, both with Firmware 17.4.1 works on both cars without isssue.
      05-09-2024, 07:08 AM   #13123
minulache
Hmm, what MCU Version? Maybe that is the problem?
      05-09-2024, 12:15 PM   #13124
hagncola
MCU on BMW 23.4.13.117
MCU on VW Golf 21.10.21.22
But with older firmware (BMW ER174 and Golf 1.6.14) with the same MCU Airplay does not work, wrote to RoadTop support for BMW and Andream for VW Golf, got for both updates and afterwards it works on both.
      05-10-2024, 01:35 AM   #13125
Jenly Tang
Drives: BMW F30
BMW Ethernet
We recently provide BMW ID7/ID8 Ethernet decoder, if anyone needs it, you can contact my Whatsapp to get the awesome price.
      05-11-2024, 06:12 AM   #13126
PinkGuy
Drives: 330e 2016
Thinking of buying this Andream unit from this website: https://www.andream-eu.com/product/ewm-bmcp/
Attatched image of my NBT version. I have a 2016 330e. It says i have the NBT Evo, but i dont know if i should order the NBT version or the EVO version from Andreams website. Anyone knows?
Also saw there was an option to flash from ID4 to ID5 or 6, but this requires a whole new headunit?
      05-11-2024, 06:41 AM   #13127
fatcatsurfer
Drives: F20
Hi everyone, can someone tell me what software I need to use to update my Andream bmw mmi box? (backside has no small parts)
package has model EW-LBMCP-NBT02B
      05-11-2024, 10:30 AM   #13128
TonyB
Drives: I3s
Originally Posted by alexusr View Post
Faced the same, had to buy from Amazon to get an order number and then returned.
Here's the B2R176R2 version from a couple of days ago for NBT B2: https://we.tl/t-qs0FcxUAOM
The link is dead, can you re upload please?
      05-12-2024, 08:50 AM   #13129
fe7565
fe7565's Avatar
Drives: 2012 BMW 328i N26
This firmware looks like from Europe, somebody else posted one similar recently. I’m not aware of any previous links or more information about these units.
Help each other: if you manage to fix your issue (especially with help from this forum), don't be a d*ck and disappear. Follow-up by posting the solution so you can help others.
      05-12-2024, 08:51 AM   #13130
fe7565
fe7565's Avatar
The best thing is to ask the seller. If they send you the wrong unit, at least you get a chance to return it.
      05-12-2024, 05:27 PM   #13131
ddubs
Drives: 2014 BMW 328d
Can anyone tell me if I have the most recent firmware for my unit? I'm not even sure what B2 version it is or what firmware list I should be looking in on the Page 1.
(of course, it uploads my picture sideways... why not, eh?)
      05-16-2024, 07:50 AM   #13132
hagncola
1.6.16_r2 should be the latest.
      05-17-2024, 04:45 AM   #13133
toddbg
Bulgaria
42
Drives: BMW X1 F48 2017 xDrive
Link please!
      05-18-2024, 01:37 PM   #13134
alfalamda
Drives: BMW 420i
I have just installed the Road Top MMI to my ID6 F36.
Since this thread is huge and it is difficult to find specific information, can somebody help with some questions?
- Do I have to connect the AUX USB to the armrest socket? I selected car BT in the settings and I could hear music but instructions from google maps were silent. I am using Android Auto. I've read several posts saying that connecting is not necessary but without the cable and the car BT setting I have no sound.
- I tried one phonecall but neither I could hear anything nor the other person could hear me speaking. Didn't change any settings as I would like to use the AA call app
- There was a mic cable inside the harness, but I don't know where to connect it. Is it necessary that I connect it? Is this why they couldn't hear me on the phone?
Tags
andream, android, android auto, apple, carplay, mmi, retrofit
f30post
