F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > AUSTRALIA > F36 Navigation maps 'loading' screen
Studio RSR
      10-29-2023, 06:46 PM   #1
Quincon
Australia
Drives: BMW 2016 340i & 2016 430i
Hi, purchased and installed Apple Carplay FSC code for an ID5 system. Installed Carplay using 'remote feature installer for BMW cars' program. Apple carplay works fine but BMW maps works for a few minutes and then just shows a 'Loading' screen. You cant go into it. I know carplay maps are probably better but would also like to have BMW maps/heads up working.
Tried to downgrade back to original, which removed Apple Carplay and the navigation screen now asks for activation code. Reinstalled Apple Carplay and maps work for a bit then show loading screen again. Updated maps to 2022 version but the same issue.
Also noticed that the ID5 screen looks like ID6 screen after upgrade, which then goes back to ID5 after downgrade.
Have attached screenshot of the FSC status, is one of them maps and possible not active?Name:  Screenshot 2023-10-29 215958a.png
      11-01-2023, 02:17 AM   #2
Shonky
Australia
17
Drives: F31 320i, E46 M3
0124 is the FSC code for Australian EVO
00A0 is the nav application
0143 is Carplay
Mine looks like (from the same application obviously)
006F0001: NotAvailable
009C0001: Accepted
009E0001: NotAvailable
009F0001: NotAvailable
00A00001: Accepted
00E50001: Accepted
01240062: Accepted
01430001: Accepted
016E0001: Accepted
016F0001: Accepted
01700001: NotAvailable
If you've got newer maps than the FSC that is loaded it will do what you say. You'd need to downgrade the maps to match that.
      11-02-2023, 04:03 AM   #3
Quincon
Australia
Thanks. it was non working even with 2018 maps. All good now and working, needed another different FSC code
      11-02-2023, 04:42 AM   #4
Shonky
Australia
17
With the feature installer version you don't really need an FSC. That's essentially what it is doing - overriding the need for a FSC or allowing one signed by someone other than BMW to work.
      11-02-2023, 04:49 AM   #5
Quincon
Australia
But doesnt the feature installer ask for an FSC code when it identifies the car? How do you use feature installer if you dont have the code and how does it know what options to activate (like apple carplay)?
      11-02-2023, 04:53 AM   #6
Shonky
Australia
17
Yes what it's likely doing is installing a version or a certificate that accepts FSCs signed by someone other than BMW.
So if that's what it's doing, it does need an FSC but it's all handled by the app when installing. It probably is just activating everything because why not. It's all "automatic" and doesn't request an FSC from the end user.
I'm interested to know what you did as an extra operation when you said "you needed another FSC code"? You mean you just removed it and reinstalled it?
      11-02-2023, 05:01 AM   #7
Quincon
Australia
The guy i purchased the FSC code from logged in remotely to my PC. I had the feature installer loaded. He ran it and i noticed it was a different FSC code. Started the program and re-flashed the head unit. All worked fine after that. Not sure if the previous FSC code had different setting, i could check it to see if any other features are now enabled that weren't before.
f30post
