02-21-2017, 10:10 AM | #45 |
Driver
465
Rep 1,002
03-17-2017, 02:15 PM | #46 | |
Rep 1,056
03-17-2017, 08:30 PM | #47 |
Driver
465
Rep 1,002
are you saying you don't think there is a reason? The first post on this thread suggests some possible reasons!
03-26-2017, 04:49 PM | #48 |
Rep 331
Drives: M140i F20 LCI-2
Good to read this sticky! Yes, the discussion will still keep popping up all over the forums. LOL
Current: Alpine White M140i F20 LCI-2, 250kW/335hp, 2018.
Sold: Melbourne Red 340i F30 LCI Luxury Line MMPK - 265kW/355hp, 2016. Sold: Alpine White 123d e82, 2010, 150kW/204hp. |
04-09-2017, 06:19 PM | #49 |
Rep 305
I noticed that someone mentioned that if you have the MPE (which I will be installing next week), it will be opened on comfort mode? How does the car know you have a MPE? I don't recall any coding involved in installing a MPE...
04-10-2017, 10:00 AM | #50 |
Rep 4,724
No, but after the car warms up both pipes work on my MPE in comfort. I don't know why
Current: 2021 M340i xDrive
Previous: '18 340i xDrive; '15 335 xDrive; '14 435i xDrive; '09 335 E92 xDrive |
04-10-2017, 04:08 PM | #51 |
Rep 305
04-19-2017, 01:48 PM | #52 | |
Rep 76
Warming up the cat faster is also for emissions, so i guess we're just saving polar bears (quote needed) with this, nothing more. |
05-12-2017, 08:23 AM | #53 |
Molar World
47
Rep 916
Great pictures on this post -- thanks. I used a plastic "zip tie" to basically do the same thing. But I like your metal clip idea better.
Have done the zip tie on my last 2 cars. 335i and now 435i. Exhaust note does sound slightly better with that 2nd butterfly valve is open all the time. You're right...takes 3 minutes max.
Current: 2016 435i Coupe
Previous: 2014 335i Sedan; 2013 328i Cv, 2011 335i Sedan Gone But Not Forgotten: 2008 135i Convertible (my favorite) |
07-25-2017, 07:22 PM | #55 |
Rep 3
Total Noob here. Just got my '15 435i xdrive convertible last Friday. Haven't had enough time to notice this exhaust "phenomenon" but now I know if I notice it. Thanks.
08-04-2017, 04:53 AM | #56 |
Driver
465
Rep 1,002
Both my tips have exactly the same amount of carbon deposit on, I guess that proves that the flap is always open in sport mode, as I ALWAYS use sport mode. Can't accept the dull throttle and light steering in comfort mode!
08-08-2017, 07:43 AM | #57 | |
Rep 9
Rick Hunter306.50 |
10-22-2017, 07:37 AM | #59 |
Rep 3,040
Hey, alternatively can't you just unplug the module after both valves are open and the baffles will permanently stay open?
2016 BMW F80 ZCP
Instagram : 7IM3LESS https://instagram.com/7im3less?igshid=YmMyMTA2M2Y= |
12-16-2017, 10:54 AM | #61 | |
Rep 32
There were no error codes and it has been about 2 yrs and everything seems to work just fine! And, yes I've check that the valve stays open and exhaust gases come out of both the tips all the time Last edited by TumblingPanda; 12-16-2017 at 11:20 AM.. Reason: valves->valve. Realized that there is only one, the left side one :P |
stuiver0.00 |
12-18-2017, 01:47 PM | #63 |
Rep 463
To address the muffler delete question, since I recently did the muffler delete.. No, no check engine lights or any codes stored.. I just wrapped up the connector neatly and tucked it under the bumper.. There's a nice little "shelf" for it..
However, be prepared for drone at low speeds, high load and cruising! To the point where, I am considering putting the stock muffler back on and perhaps at some point getting the AA exhaust or similar. At (cold) startup it sounds loud as hell, then drops down to a nice rumble, would be nice if this low rumble was the "stock" sound, post muffler delete.. I will miss the pops and crackles at gas let off, but growing tired of having to shift to combat drone.. |
01-01-2018, 04:11 PM | #64 |
Rep 26
I think my flap is frozen or stuck closed. My left pipe (single sided 428i exhaust) is frosty and ice covered (-25 to -30 deg C for the last 2 weeks here).
I am trying to get the valve open so that I can disconnect the electrical connector. My question is, if I can't get the valve opened normally through the cars exhaust logic and vacuum, will the 'wire mod' open the valve as I tighten down and twist it in place? |
01-02-2018, 03:16 PM | #65 | |
Rep 92
This is all about tuning the exhaust for best all round performance. Disabling it will also affect the cars fuel consumption ie. it will get worse as the engine is not running efficently as intended. It may also take away some of the smoothness in start up and normal acceleration. Just my two pennys worth. CT |
01-09-2018, 05:33 PM | #66 |
Rep 967
Drives: 2016 F36 435x MSport
sucks, i wish i came here before i ordered the exhaust dummy plug. You can add me to the list of 'i noticed the f36 def has a different logic for the flap'.
I wonder why.... PS. the bit about backpressure is hogwash. wayyyy too far downstream to impact backpressure lol. As mentioned it is for cat efficiency, but also because cold starts on this car are quite a bit "loud" (if you have a DP, you know...) for the non-car-fanatic BMW drivers.
2010 Mazda RX8 - Sold (11/17)
2016 BMW 435xi GC - Current |
