04-15-2024, 02:47 AM | #1 |
Rep 48
Has anyone had all of these codes at once before?
I have a 2016 340i that's been throwing a bit of a tantrum lately. This all started when I was stuck in bumper to bumper traffic. I had to stop on a hill a few times as traffic crept along, which is when these issues arose.
The car started complaining about the brake system, and was throwing codes all over the place for all things brake related. Now, I had all brake discs and pads changed towards the end of last year by BMW, including brake fluid, as well as a brake flush. The error codes are as follows - - Brake System Fault. Please contact your BMW service partner. - Daytime Pedestrian Warning Limited. Brake Intervention not possible. - Frontal Collision Warning Malfunction. Brake Interventio not possible. - Chassis Stabilization. Proceed Carefully. These 4 always come up together, but the brake system fault goes away soon after it comes up. The rest are persistent. Everytime you drive the car, these errors come up. I will post codes when I scan the car, but in the mean time, has anyone had this issue before? If so, what was the root cause of this issue? And how did you fix it? Thanks for viewing! |
04-15-2024, 04:34 AM | #2 |
Rep 79
I had a similar thing happen, although I had the ABS light and Tyre pressure monitor light come up. It happened very intermittently. I replaced an ABS sensor and all has been well since.
Billfitz8299.50 David Kunitz736.50 |
04-15-2024, 05:45 AM | #3 | |
Rep 48
Thanks for the reply. Appreciate it. |
04-15-2024, 11:11 AM | #4 |
Rep 1,703
Drives: 2014 428i and 2018 X5
How old the battery? If old, get a battery tester and test it. Lots of weird things like this happen when the battery starts to go...
___________________ 2014 F32 428i M-Sport 2018 F15 M-Sport |
04-15-2024, 12:00 PM | #5 |
Rep 16,192
Anything that uses wheel speed information won't function if there's an ABS fault.
alohasurftoad3132.00 David Kunitz736.50 |
04-15-2024, 12:17 PM | #6 |
Rep 4,380
i've had similar faults always caused by a faulty wheel speed sensor. i've had to change 3 wheel speed sensors and recommend using genuine BMW parts.
it's a fairly easy DIY you need to get an OBDII code reader it will tell you which abs or wheel speed sensor that needs to be changed. . Last edited by alohasurftoad; 04-15-2024 at 12:24 PM.. |
04-16-2024, 09:43 AM | #7 | |
Rep 48
I had originally suspected the battery as well but I don't think the battery is the issue. |
04-16-2024, 09:44 AM | #8 | |
Rep 48
04-16-2024, 09:45 AM | #9 |
Rep 48
alohasurftoad said the same thing. To me, it's now the ABS Sensor
Last edited by GipsyD; 04-16-2024 at 10:14 AM.. Reason: Realized that the ABS Sensor is the Speed Sensor. |
04-16-2024, 11:18 AM | #10 |
Rep 16,192
That's one possible cause. Scanning for error codes is a must. The battery is probably the least likely cause. There can be a low voltage issue, but more often than not that's caused by parasitic power drain by something. The dashboard and water pump are two examples.
04-16-2024, 11:27 AM | #11 | |
Rep 4,380
basically if the wheel speed sensor is faulty, it disables the ABS because it doesn't have wheel speed info. in your situation, it may be the ABS sensor, as you suspect. the OBDII scanner will indicate which ABS sensor is faulty. |
04-20-2024, 03:22 AM | #12 | |
Rep 48
04-20-2024, 03:29 AM | #13 |
Rep 48
Alright, so these are codes that my car is throwing -
21A02D - Combustion Control Valve Lift 118002 - Mixture Control - Mixture Too Rich 101F01 - Throttle Valve Angle 118041 - Mixture Control - Mixture Too Lean - Large Deviation 118001 - Mixture Control - Mixture Too Lean I think this is pointing to a bad VANOS Solenoid, but the car drives fine, and has all of it's power. I did the valve cover replaced, but that was about 2 years ago. TBH, I am not too worried about these codes, as they aren't hampering the car's performance. 48002C - LDM Function - High Level Operational Readiness - Brake Control Unit 480932 - Brake Fluid Sensor - Brake Fluid Too Low E06C43 - Signal Status Invalid or brake chain not available B7F343 - Backup Battery Failure In total, this car has 9 codes now. I pulled these codes using Bimmerlink using a VGate BT OBD Adapter. I don't see anything pointing to an ABS sensor. Only for a low brake fluid level, which I find highly unlikely considering I had the brakes, fluid and rotors changed at the end of last year. Any ideas? |
04-20-2024, 07:44 AM | #14 |
Rep 4,380
480932 seems the most suspicious. Are you able to clear it? If not, that's where I'd start troubleshooting from, especially since you did work on the brakes recently.
You may have to have a reputable indy mechanic asses as well. I have an autophix scanner that is a foxwell knockoff. it is able to clear codes. the bimmerlink should be fine, though. |
04-20-2024, 08:19 AM | #15 | |
Rep 4,924
You can check the fluid under the hood, next to the windshield, driver side. There are 3x 10mm plastic nuts that need to be turned CCW 1/2 turn to release the clips near the windshield, and then that plastic pulls straight off. Brake cylinder is right there. |
04-20-2024, 09:04 AM | #16 |
Rep 629
Are all those codes currently active or just stored?
Check battery voltage (both running and anfter sitting for a while) Check brake fluid level while waiting. |
alohasurftoad3132.00 |
04-21-2024, 03:19 AM | #17 | |
Rep 48
If the fluid reserve is low, then I'll take to a mechanic to check it out. |
04-21-2024, 03:20 AM | #18 |
Rep 48
These codes are stored as intermittent issues. After clearing the issues via OBD, the errors will come back after driving a bit.
04-21-2024, 03:24 AM | #19 | |
Rep 48
04-21-2024, 08:38 AM | #20 | |
Rep 4,924
You might be in a case were it was just borderline for ever, and just tripped the sensor, or maybe the brake level sensor is bad? Last edited by Wires; 04-21-2024 at 09:18 AM.. |
05-02-2024, 10:13 AM | #21 |
Rep 48
UPDATE - I managed to fix my car by taking it to an indy. The indy re-learnt all of the car's major systems, from VANOS to Fuel Mixture, and that fixed my issue. No more lights whatsoever.
With regards to the brake system, we topped off the brake fluid and re-learnt the brake systems as well. Before relearning everything, the car was still throwing the codes as before. After relearning, all the codes went away . Long story short, re-learn it all! Thanks for all the input guys! Appreciate it! |
05-02-2024, 10:33 AM | #22 |
Rep 1,828
Sounds a lot like someone on the 2series side. I miss diagnosed, but the person was able to figure out it was actually just low brake fluid.
https://www.2addicts.com/forums/show....php?t=2096001 |
Tags |
340i, b58, brakes, errors, faults, issues, sedan |
