F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Upgraded yellow DRL's flashing?
Extreme Powerhouse
      04-27-2024, 06:13 PM   #1
RG428i
Drives: BMW F32 428i 2013
2013 BMW 428i   [10.00]
Anyone know why when i've put yellow drl's into my f32, they seem to flash on and off and then go off, when im driving they seem to be fine as far as im aware, but when my engine isnt on they flash then turn off,
I assume its something to do with the voltage dropping when its not running but im not 100% sure, if you have any insight please let me know?
      04-27-2024, 09:58 PM   #2
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
Did you change to LED? If so they need coding.
      04-28-2024, 03:09 AM   #3
RG428i
Yeah i think so, I've attached an image if the ones i bought, is it something i can do on bimmercode? Just change the Bulb bit to LED?
      04-28-2024, 07:22 AM   #4
Billfitz
Billfitz's Avatar
Correct. If Bimmercode shows them already coded as LED then something else is remiss.
      04-29-2024, 05:12 AM   #5
RG428i
Ok, got a bimmercode obd coming today so will check, my carly doesnt allow me to check cos its shit
      04-29-2024, 01:30 PM   #6
RG428i
Bimmercode shows them as Active on led conversion? So i assume this means they have been changed to LED ones right? Didnt let me code anything yet as i need to purchase the full version but for DRL's it said active?
      04-29-2024, 03:26 PM   #7
Billfitz
Billfitz's Avatar
That probably indicates that the originals were LED, so the problem isn't the coding.
      04-29-2024, 04:13 PM   #8
RG428i
They isnt coding around it tho? Its just plug and play so unless the curcuit boards are just shit, could it not be a voltage issue?
      04-29-2024, 10:46 PM   #9
Billfitz
Billfitz's Avatar
It's the same voltage as you had before making the bulb switch. Logic says the bulbs are the problem.
      05-02-2024, 08:29 PM   #10
Wires
Drives: 2016 340i xDrive
You did buy them off AliExpress. Sometimes a deal isn't always a deal.
f30post
