05-03-2024, 11:28 AM | #1 |
Rep 10
Vland GTS light behaviour
I just installed the set on my car and while everything works I'm a bit puzzled about their behaviour. If I have my lights set on Auto then they are completely dark, the dragonscales don't light even though the angel eyes on the front do. Is that normal?
05-03-2024, 06:31 PM | #3 |
Rep 1,703
Drives: 2014 428i and 2018 X5
Yes, that’s normal… DRL’s by default are only for the front of the car.
___________________ 2014 F32 428i M-Sport 2018 F15 M-Sport |
05-03-2024, 06:35 PM | #4 | |
Rep 93
And if you want the startup animation you need to make sure the light switch is on auto , and welcome light is enabled in the I drive |
05-10-2024, 07:50 AM | #5 |
Rep 10
The thing is that I have a EU-spec F33 LCI and I'm 99% sure that the DRL for the OEM taillights did light up during driving with the Auto light mode.
Which option in Bimmercode are we talking about exactly? |
05-11-2024, 02:26 AM | #6 | |
Rep 648
Drives: 2018 F48 X1 xDrive 18D
You are looking at the REM module in BimmerCode where you can change it. |
05-11-2024, 07:42 PM | #7 |
Rep 1,821
I found a thread that tells you what needs changed to enable rear DRL if you don't have the VO code 8TL enabled.
https://f30.bimmerpost.com/forums/sh....php?t=1302702 |
05-12-2024, 04:25 AM | #8 | |
Rep 648
VO-code is basically a template of several FDL-code settings. Also know as cheatsheets in the BMW-coding world. Bimmercode easy mode does the same, 1 setting might change several FDL-parameters. You can verify that by flip a switch in bimmercode easy mode and then go to the FDL-parameters in expert mode (if you happen to know them) and you’ll see the FDL has changed |
05-14-2024, 02:55 PM | #9 |
Rep 10
Thanks everybody for chiming in, got it working. Enabled the DRL option in Bimmercode and the tails light up properly now.
mobbinthesteez22.50 |
