08-28-2016, 11:02 AM | #1 |
Rep 938
Drivers glovebox installation
There's been a few requests for this install on the forums so here it is.
The drivers glovebox comes when you order the storage package as an option however if the original owner doesn't include this, you end up with missing cubby holes to store items. The drivers glovebox is a neat little storage space that fits your wallet, phone, keys, etc so very useful. All F30/31 cars can have this retrofitted if you are willing to take a knife to your dash... This sounds a lot scarier that it really is, but if you take your time and go slowly without hacking huge chunks away, it's a very easy install to complete. Lets start with part numbers first (for LHD cars): 51459240633 - Glovebox 51459267520 - Glovebox fixing bracket 07149185673 - Screws to hold bracket in place (TORX 20) And here are the parts in all their glory! Lets start with how things looked before the install. It's a sad empty space. Before I started hacking away at the dash, I had to remove a couple of items. The first item to remove was the air vent which is easily done by gently prying away at the left edge (LHD car remember), and then working my way around the vent component until it pops out. The next item to remove is the light switch. Again, this is very easy when you know how. There are two clips on the top edge of the switch which, when pushed down firmly, will allow the switch to pop out at the top of the dash. When that is released, the rest comes out easily. Whatever you do, don't force it! It will ease out. And this is the inside. You should at this stage, remove the sound deadening material on the back of the part of the dash that you will be removing. This will make cutting it much much easier! You can see my Bimmertech amp harness in the background. Before I started cutting, I created a template of the front of the glovebox. Mental note, do not cut outside of this template. I created a starting square within the the template to cut out first. The dash is pretty thick. I actually started with a dremel but gave up on that quickly. I think I probably had the wrong cutting discs, but the dremel created a lot of smoke as it was melting the plastic. I switched to using a sharp knife which worked out much better. My knife also has a serrated edge so that helped further. After a lot of cutting and slowly taking more and more away, this is the final hole. Top tip! Don't go for the full hole right away. Take your time and chip away at the dash little by little so you don't take away too much. The mess.... And here's the glove box fitted. You have to insert it at an angle and then push it down into place. Remember that sound deadening material I removed initially? I stuck it on top of the glove box to help reduce the sound deadening. I then attached the bracket which holds the glovebox in place. It also pulls the glovebox up which gives it a much better fit. Two screws hold the bracket in place. They are screwed in from inside the glovebox itself using a TX 20 socket. And you're done! Reattach the light switch and air-vent and after a little vacuuming you're done! Below is the result and a very handy cubby hole to keep my wallet and keys!
Current car: 2017 BMW G30 520d M-Sport, BMW F46 218d Grand Tourer
Previous cars: 1989 BMW E30 316i, 1998 BMW E36 323i Coupe M Sport, 2009 BMW E87 116d, 2013 BMW F31 320d M-Sport Last edited by beanbaguk; 08-28-2016 at 11:34 AM.. Reason: Fix images |
08-28-2016, 11:22 AM | #2 |
Rep 164
Drives: 2024 G87
[QUOTE=beanbaguk]There's been a few requests for this install on the forums so here it is.
The drivers glovebox comes when you order the storage package as an option however if the original owner doesn't include this, you end up with missing cubby holes to store items. The drivers glovebox is a neat little storage space that fits your wallet, phone, keys, etc so very useful. All F30/31 cars can have this retrofitted if you are willing to take a knife to your dash... This sounds a lot scarier that it really is, but if you take your time and go slowly without hacking huge chunks away, it's a very easy install to complete. Lets start with part numbers first (for LHD cars): 51459240633 - Glovebox 51459267520 - Glovebox fixing bracket 07149185673 - Screws to hold bracket in place (TORX 20) And here are the parts in all their glory! No pics come through
[/SIGPIC][/SIGPIC]2016 f32 Alpine White On Porno Red
M Sport, 6MT, Dinan Stage 4, Dinan CF Cold Air Intake, Dinan Intercooler, Dinan Big Turbos, Remus Sport Catbacks, and lots of Carbon Fiber Eye Candy Last edited by fatalkarma; 08-29-2016 at 11:05 AM.. |
08-28-2016, 11:23 AM | #3 |
Rep 938
Hmmmmm.....tried with Google Photos but that looks like it was a fail. Will try another way...thanks for letting me know.
Previous cars: 1989 BMW E30 316i, 1998 BMW E36 323i Coupe M Sport, 2009 BMW E87 116d, 2013 BMW F31 320d M-Sport |
08-28-2016, 11:35 AM | #4 |
Rep 938
Images should be fixed now!
fatalkarma46.00 |
08-29-2016, 09:25 AM | #7 | |
Rep 938
My tip would be to leave a 6mm border inside the indent of the glovebox area and cut short towards the bottom of the glovebox. Just keep trimming away millimetre by millimetre so you don't end up going too large. Also use a very sharp knife and for cutting away at the dash. You can also use a file but that will just end up creating a lot of mess and dust. If you want to use a dremel, you will need to buy plastic cutting discs as my metal cutting discs simply melted the dash I was cutting and generated a ton of smoke! My next challenge is to cut a hole where the centre speaker goes to install a centre channel for my PP-82DSP amp, and I also plan to upgrade my HU to an NBT EVO.....fingers crossed.
jhuber65.50 |
08-29-2016, 09:53 AM | #9 |
A family of bimmers
2757
Rep 7,743
Great DIY!
you know you can just respond to the thread and not quote the OP, right? sooo much scrolling now. can you please edit your post to not quote that?
2018 PB/Black G01 X3M40i | 699M | ZDA | ZPP | ZPX | Maxton front lip | X3M vents | 15mm Spacers | Diamond G20 style grills |
08-29-2016, 11:05 AM | #10 |
Rep 164
Drives: 2024 G87
got you, did it on iphone, the app has some bugs.
M Sport, 6MT, Dinan Stage 4, Dinan CF Cold Air Intake, Dinan Intercooler, Dinan Big Turbos, Remus Sport Catbacks, and lots of Carbon Fiber Eye Candy |
09-03-2016, 11:55 AM | #11 |
Rep 220
I dont think this mod works if you have the Drivers Assistance System (active blind spot detection, Collision Warning, Lane Departure Warning). I think these three buttons reside at the top of this optional drivers glove box.
09-05-2016, 03:24 AM | #12 | |
Rep 153
08-13-2021, 08:22 AM | #13 |
Rep 275
sorry for the 5+ year bump but i don't suppose you could make the photos live again could you?
Previous: 2002 E46 330i M-Sport (m54b30 LCI), 2007 E92 335D M-Sport Coupe (m57), 2003 z4 3.0i (m54b30), 2010 E92 325D M-Sport Coupe (n57 LCI), 2019 F36 430i M-Sport Pro Gran Coupe, 2018 F36 440i M-Sport Pro Gran Coupe MPPSK
Current: MY2021 M550i, Aventurin Red, Ivory Nappa, Comfort Pack, Tech+ |
04-24-2024, 02:05 PM | #16 |
Rep 280
Here's a pic from a while back when I added the driver's glovebox to my car:
I first removed the vent, then the light switch assembly, remove the insulation behind the dash where the cutout will be, then created a cardboard template of the hole required to fit the glovebox, marking with a sharpie the horizontal and vertical center-lines of the box. On the dash, lay some masking tape on the dash, marking the center of the area where the cutout should be, then extend the lines to the edges of the area for the glovebox cutout. Then lay the cardboard template on top of this, lining up your centerlines. Then draw the edges of your template onto the masking tape on your dash. Then use a dremel or fein multimaster to make your initial cut 1/4" inside this template cutout, then carefully test fit the box, expanding the cutout hole as needed to fit the box and keep it level. Don't forget that the bezel around the glovebox will hide any minor gaps or the "roughness" of the cut. I can tell you that using a Fein multimaster with a narrow cutting blade is the perfect tool to make this modification, and will make this job quick and effortless. Such a useful tool around the house as well.
2017 430ix Gran Coupe
