F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > Depo LCI Tail Lights
Extreme Powerhouse
      01-22-2019, 09:26 PM   #89
Kailec
Kailec's Avatar
Drives: 2013 328i xDrive
Originally Posted by rayjuan View Post
update:
i just emailed fishcake on his depos and realized the ones i bought only came with the red led turn signals! now ill have to change them bulbs
does anyone know what led bulbs are for the depos turn signals? i figured that the reverse bulb is H21W.
is it safe to open up the depos for bulb changes???
I don't think it's safe to open up the housing if that's what's needed.
      02-06-2019, 05:49 PM   #90
DaGreat81
Drives: F30
I have the blackline DEPO LCI taillights and I'm getting condensation issues. I received replacement sets of these lights and I'm still having condensation issues, I do not think it's going away unfortunately, it goes and comes back
any input on this? These lights look great but theyre poor quality
      02-10-2019, 09:44 AM   #91
EDWYER
Yoda of mods
EDWYER's Avatar
1679
Drives: X5 RWD
2015 X5 RWD  [0.00]
2016 BMW M2  [10.00]
Damn. OEM for me.
Current: 2020 Explorer ST (Agate Black Metallic) AWD, F15 SGM RWD
F87 AW (retired) F30 SBM 316rwhp/440rwtq (retired)
Follow me on Twitter: https://twitter.com/EdwyerCLT
YT: https://www.youtube.com/@DWYERGARAGE/videos
      02-15-2019, 10:36 PM   #92
f32ftw
f32ftw's Avatar
Drives: BMW 435 xdrive
Will they ever make these for the F32?
      05-19-2019, 06:58 PM   #93
Craeftig
Drives: BMW 2014 F30
Originally Posted by Bryan_KiesMotorsports View Post
Originally Posted by pentagon View Post
I also had trouble getting the inner lights in, what i did was align the inside of the lamp (side with the nut) then pulled the lamp outwards to get the clips to go into the holes on the trunk. It took a bit of finesse and luck to get everything lined up.
Also, it appears that the insulation foam around the inner light is different than OEM, the depo foam is thicker and the outer edge actually moves a bit when i tried to press on it. Overall, the quality seems decent and hope the insulation foams will last.
Edit: any long term owner of these lights? I noticed that the outer light harness is not really waterproof (exposed connectors and etc). The area where the harness/resistors are located is not waterproof by design, so I'm worried about the long term exposure to water. So far I've used electrical tape to mask the exposed connectors and will coat it with silicone gel.
I've had mine for maybe 9 months or so, without issues. My set was a development set, so I had an issue with the inner light coming a little loose, but the ones on my car were hand made and were just a prototype. Nothing a little 3m tape couldn't fix, but you shouldn't need it on the production lights.
Bryan
Why doesn't ur company sell the blackout version?
      06-05-2019, 03:00 PM   #94
MFNATIK
Blocked from G80/G82 for having an opinion
MFNATIK's Avatar
Drives: Trek Domane
I have an OEM LCI set for sale if anyone is interested
      06-06-2019, 09:47 AM   #95
blumagic
blumagic's Avatar
313
Drives: 2014 328i xdrive , 2013 SHO
In other cars I have owned with aftermarket taillights with this issue, clear silicone around the lens where it meets the housing solved the problem
      10-11-2019, 03:01 AM   #96
palomino05
Drives: 2013 328i sedan
hey what is the part number for the LCI dip rails? thank you so much.
sthor1022.50
      10-11-2019, 02:36 PM   #97
IK6SPEED
Drives: BMW M3 / AH3
Trim, drip rail, left 51497453333
Trim, drip rail, right 51497453334
      10-12-2019, 04:11 AM   #98
palomino05
Thank you so much, do you know if these are needed for the retrofit?
      10-17-2019, 08:56 AM   #99
thompsac25
Stance to make her dance
thompsac25's Avatar
722
Drives: 2023 G80 M3
LCI drip rails are not needed for DEPO tails. I recently installed DEPO Blacklines from USR and reused my OEM drip rails. My install videos below show the drip rails and I talk about these in a little more detail. Some people have claimed that theyve seen condensation in their taillights and when they replaced with LCI drip rails, the issue disappeared. I havent had any problems thus far.
Hope the link below helps you...
https://f30.bimmerpost.com/forums/sh...&highlight=usr
INSTAGRAM: thompsac_m3 YouTube: ACCELERATED MOTION
2023 G80 CX M3, Individual BRG
      10-24-2019, 11:53 PM   #100
SMiGGs
Drives: Msport
For those with the condensation problems is with any type of non-oem head light or tail light is that they wont ever be near as good as OEM.
What i do whenever i get a replacement light for any vehicle, especially from ebay or anywhere else, i place a thick bead of silicone over the edge of the light. I also add a clear wrap over them or ceramic them. If you already have condensation, dry them up, and then seal them with silicone.
      01-04-2020, 08:39 PM   #101
Eggsi619
Eggsi619's Avatar
14
Drives: f30
I'm in the process of installing Depo LCI tail lights that I purchased off of USR. Great set of lights for the amount paid. However upon installation, I did notice the thicker insulation around the tail lights. It does have a bit of play if you firmly press on it which is concerning since part of the tail light does not sit flush against the body.
I'll go ahead and take SMiGGS advice above but I was wondering how your lights are holding up now, to those who have it. My main concern would be when washing the car and overall, heavy rain. Do you notice any deterioration on the insulator?
*EDIT
Tail lights installed. To those who are very particular, here is a photo of the the inner tail light not sitting flush against the body.
      01-05-2020, 10:14 AM   #102
rcaso26
rcaso26's Avatar
Drives: 2015 328i xdrive
I have been running the depo tail lights for more than a year now and have not had any condensation issues. I definitely agree with your comment that the surrounding material has some play to it and I even notice that this foam material gets wet when it rains but honestly I don't think too much into it as long as no condensation gets into the lights. Hope this helps!
      04-04-2020, 08:57 PM   #103
DV
DV's Avatar
Drives: F36 440i
When are these available for the F32??
Been waiting patiently and an OEM set is currently $1200.
      10-22-2020, 11:02 PM   #104
debilashka
Drives: BMW 320i
So .. regarding tapping to make the inner tails signals work, is the black/gray wire for passenger side and black/white for driver?
      04-06-2024, 10:01 PM   #105
elipiz13
Drives: BMW 335 F30 xdrive (2014)
Anyone have any issues with depo black line LCI taillights both blinking when turn signal is initiated
f30post
