07-04-2018, 12:05 AM | #23 |
Noob
37
Rep 58
So I grounded the yellow/black wire from the TMAP harness and...no change. Same codes. Not sure what my next step would be other than taking it in to the dealership....
07-04-2018, 08:21 AM | #24 |
Rep 558
Ok. When I grounded the tmap harness, the "drivetrain malfunction" message immediately went away as soon as I turned on the car. But the CEL will stay unless you CLEAR it. Did you clear it with the software tool you have? Before grounding, the car would not let me clear the CEL.
07-04-2018, 10:30 AM | #25 | |
Noob
37
Rep 58
07-04-2018, 10:32 AM | #26 |
Noob
37
Rep 58
Yep, tried this earlier in the week. It appears that all 3 TMAP sensors I have (1 new one) are functional as I have rotated all 3 through the 2 possible locations - CP and manifold - with no change in error codes.
07-04-2018, 10:50 AM | #27 |
Rep 558
Well...unless you have ISTA in your toolbox, it can tell you exactly where to look. Sometimes you gotta throw in the towel and take it to the dealer. Good luck man. Keep us posted.
07-04-2018, 06:02 PM | #28 |
Rep 22
Drives: 2014 335i Estoril Blue M-Sport
So, not sure if this will help but when I did my mhd flash this happened to me. The culprit was in my sub settings for the map where it gives the option to select 3.5bar (n20) sensor. I selected by mistake without having the upgraded 3.5 bar tmap sensor. Went in reflashed st1 map without that selected and it was immediately cleared/fixed. Check and see if you have that selected if you haven’t upgraded to the 3.5 bar tmap sensors.
Just Ask37.00 |
07-04-2018, 10:21 PM | #29 | |
Noob
37
Rep 58
07-04-2018, 11:42 PM | #30 |
Rep 22
09-10-2018, 09:06 PM | #31 |
Noob
37
Rep 58
Followup:
The issue was that the wire harness from the TMAP sensor in the CP to the ECU had been pulled out of the ECU, thus no signal was being sent. When the CP blew it also dislodged the harness from the intensity of the "explosion" that occurred when the CP blew apart. Indy shop rewired the harness and I am now good to go! |
_bdiddyb_215.00 |
09-13-2018, 09:22 AM | #32 | |
3442
Rep 79,211
Drives: C6 Z06, 09 335i, 10 335xi
09-13-2018, 11:10 PM | #33 |
Noob
37
Rep 58
It damn sure was loud!! My initial 50 millisecond thought was a blown tire, then the loss of power told me otherwise. The CP didn't just crack, it shattered...the top 2 inches of pipe were gone. The old harness was fairly short, enough so that the end result is not surprising.
09-14-2018, 12:33 PM | #34 | |
Rep 5,400
Drives: 2015 BMW 335i x-Drive Auto
Just Ask37.00 |
09-14-2018, 09:20 PM | #35 |
Noob
37
Rep 58
02-08-2020, 10:28 AM | #36 |
Sustinendum Victoriam
82
Rep 349
02-08-2020, 02:03 PM | #37 |
Rep 5,400
Don't remember, that post was over a year ago. If you have a Bentley manual read through it for great information.
11-17-2022, 03:19 AM | #38 |
Rep 2
I tested continuity by grounding the black/yellow TMAP wire to four different points on the frame...none. In addition, I checked for voltage by running a multimeter between the black/yellow TMAP wire and the positive terminal in the engine bay...zero voltage. After disconnecting the TMAP harness, I used MHD to clear and read the newly generated codes. There are the same codes regardless of whether I have the TMAP harness plugged in, so it appears to be a wiring issue. Would it be good to ground the black/yellow TMAP wire directly with the JB4 ground "fix"? please get in touch with me at https://gbfunda.com/yo-whatsapp/ which I install from GBFunda. I shall be very thankful for this.
11-20-2022, 06:15 AM | #39 |
Rep 3
11-26-2022, 01:40 PM | #40 |
Rep 13
I had the same on my M135, I actually had an aftermarket chargepipe on it but for some reason that just didn't fit properly. It popped off on dyno during a pull ripping the harness in pieces lol. Fixed them and no issues.
I had to grind the inside of that chargepipe to make it fit fine, probably some production issue that company had at the time. But since then, all good! Pulls good on pumpgas and BM3 OTS |
