04-16-2024, 06:44 AM | #1 |
Rep 109
I want my N55 redline at 9000rpm
04-16-2024, 11:06 AM | #2 |
Eh?
252
Rep 88
The builders Instagram has more videos of it. Neat concept, it sounds absolutely insane and very RB like for sure.
https://www.instagram.com/4n_motorsport/?hl=en |
04-17-2024, 08:08 PM | #3 |
Rep 292
Drives: 2014 335i 6MT MSport
That sounds gives me the chills.
2014 F30 N55 6MT, gray/red, M-sport, VMR 710/Mich PS 4S, MPPK, MPE 2001 E53 M54 5MT peeling green/black, well-optioned |
04-18-2024, 04:41 PM | #4 |
Rep 3,680
Been following this guy on Instagram... absolutely insane build. Love to see new stuff being done with the N55.
Instagram: rjd_f30 | Current: EBII 2013 335i 6MT RWD & Sprint Blue 2008 Audi RS4 | Retired: 2013 328i, 2000 XTerra, 2022 Civic Si |
04-20-2024, 09:55 PM | #5 |
Rep 1,122
Drives: 2015 BMW 435i Xdrive MSport
It is for real. It's a custom built destroked N55. He'll be offering this exact build for customers real soon. I can't imagine it'll be any cheaper than a fully built 3L N55 goes for. This build is definitely more entertaining than the carbon copy builds out there.
2015 435i Xdrive (Klaus)
Stanced 8th Gen Honda Civic (The daily) |
04-22-2024, 10:47 AM | #7 |
Rep 1,386
The equal length header manifold is already for sale, I believe they're only making them available for 2 different turbos though and the price begins at $6.5k (that's just headers).
Out of curiosity can anyone chime in with experience around equal length builds - if you had the headers remade at equal length would there be much change in sound? I understand the flow would be a lot better as the standard N55 headers are pretty terrible. I had my friend who builds custom exhausts quote me up and it was pretty reasonable - he mostly works on custom titanium builds for Porsche and McLarens but was happy to build this.. problem is I don't really fancy sinking a few hundred £'s if the equal length doesn't change anything (I know it won't be a 9k screamer)
2015 435i - 401whp
Scorpion catless dp, VRSF 6.5" HD FMIC, MST V2 inlet, NGK 97506, MHD Stage 2+ 102, xHP Stage 3, M Performance Exhaust (modified for valved straight thru) |
04-24-2024, 12:39 AM | #9 | |
@_sunbish
284
Rep 611
oMg 90o0 RpM!!!!!111
'14 435i RWD - BM3 stage 2+ E30/bolt ons/stock turbo/full drag pack -- [10.9@125].....60 to 130 - 8.5
'16 340i RWD - BM3 stage 2+ E50/bolt ons/stock turbo/full drag pack -- [10.2@131]......60 to 130 - 7.5 |
04-24-2024, 07:31 AM | #10 |
Rep 1,122
It's a worked head. He's got like close to 30psi through the motor revving to 9k.
04-24-2024, 12:42 PM | #11 | |
Rep 4,185
04-24-2024, 05:05 PM | #12 |
Rep 1,122
For a 1000Hp build of what he has it's 23k on his website.
04-25-2024, 12:13 AM | #13 | |
Rep 4,185
That was an engineered piece, where his VQ made 4xxwhp when people were struggling to make over 300whp. Yeah tubular manifolds can make more power IF they are sized correctly. This just seems excessive for what they are. 3k maybe. But $6500 is outrageous. |
04-25-2024, 10:20 PM | #14 |
97
Rep 28
$6,500 is for a full frame complete turbo kit ceramic coating included with an EFR 8474, 9274, or 9280 turbo. it’s also on sale right now -500 off.
The 4N-N5X EFR kit comes with a custom motor mount bracket to clear the EFR turbo, heat shielding, PNP coolant pipe, a tab to lower the water pump, turbo oil pressure fittings and line, drain line, single 3.5 DP, 3.5 standard intake. Water reservoir tank relocation to driver side is required. This kit can be configured with your factory EWG or IWG actuator. Last edited by 4N Motorsport; 04-25-2024 at 10:27 PM.. |
04-26-2024, 01:53 AM | #15 |
Rep 779
Do our cars have headers? Or is it the turbo manifold? I’ve seen the M2 N55 has a better flowing turbo manifold than the F3x N55, better flow and less than $1k.. just gotta confirm fitment
MG F30 M-Sport 6mt FBO w/ MHD stage 2 plus (PWG), ST XA Coilovers, 19" VMR V804.
04-26-2024, 08:34 AM | #16 | ||
Rep 4,185
The stock head flows terrible, and this has been known for a while. All you're doing is asking a slower spooling big turbo to use brute force overcome it. You could make 600WHP without a built engine - I know 2 people on the forum doing it now. N54 heads flow the same as N55 heads: You can have VAC build a complete engine as well, including higher displacement or changing the rod/stroke ratio keeping the displacement at 3 liters. I assume since they sell heads, they are included in the build if you want it: Stage 1 starts at $1,300, and supposedly is a small bump in flow. $2,700 If you want stage 2 which already includes an upgraded valvetrain minus cams: https://store.vacmotorsports.com/vac...n55-p4779.aspx Full on Race engine: https://store.vacmotorsports.com/bmw...n55-p1464.aspx Camshaft: https://store.vacmotorsports.com/sch...s55-p4950.aspx I love the idea - especially as a guy who came from Japanese cars and loving all things (classic) Nissan, but this kit needs refinement. Quote:
I'm wondering if Pure or anyone else who takes N55 cores differentiates between the M2/X40i manifold and turbo and the standard EWG.
Mods: Yes.
04-26-2024, 09:41 AM | #17 |
Rep 4,185
For what it's worth, I believe the RB26DETT head flows 23X -24X CFM Range.
You can see a 380WHP GTR with a 8000RPM Redline go to 600WHP and beyond, including the benefits of headwork. FYI this was on 94oct: https://dsportmag.com/the-cars/proje...ne-in-the-u-s/ https://dsportmag.com/the-cars/part-...d-part-2-gt-r/ https://dsportmag.com/the-cars/part-...part-3-gt-r/2/
Mods: Yes.
Shaq937.00 |
