05-08-2020, 10:20 AM | #221 |
Rep 1,122
Drives: 2015 BMW 435i Xdrive MSport
Unfortunately, BMW discontinued the LSD for the automatic transmissions 335i/435i.
2015 435i Xdrive (Klaus)
Stanced 8th Gen Honda Civic (The daily) |
05-08-2020, 11:58 AM | #222 |
Rep 787
Here's a recent post of a forum member who did the wavetrac
https://www.bimmerpost.com/forums/sh...php?p=25898738
335i rwd auto, 2015 with m performance LSD and Dinan stage 2. Cts charge pipe, mad 5" stepped intercooler.
Poochie9107.50 |
05-15-2020, 03:36 PM | #223 |
Rep 963
Only put 150 miles on it, but the stability at high speeds has been pretty incredible. Just highway driving so far, but so much easier to take these big sweeping turns at 90+. Can't wait to start pushing it in the canyons.
2018 Azurite Black F80 M3 ZCP
2019 Phytonic Blue G05 X5 2013 Glacier Silver F30 335i (sold) |
05-17-2020, 02:48 PM | #224 |
Rep 3,958
Your limited slip differential is providing you greater stability at higher speeds on a highway? Maybe if you have 2000 horsepower and can break traction at 80mph.
05-17-2020, 03:12 PM | #225 | |
Rep 963
06-24-2020, 12:41 PM | #226 |
Moto Lover
187
Rep 591
Drives: '19 BMW S1000XR
If anyone has one for sale in Socal for a F30 335i RWD auto transmission, let me know
06-28-2020, 09:25 PM | #227 |
Rep 1,934
Rwd and xdrive use the same lsd part #. Just matters between auto and manual transmission. Good luck with the search
F30 335iX | Remus Axleback | Fabspeed Catted DP | VRSF Comp IC | 18X9 ET35 19lb MT1 | 255/40/18 ECS | Ohlins RT Millway Street | Millway Control Arm Bushings | Turner Endlinks | TMH 75mm 14x1.5 Studs | BMW MPerf LSD | XDelete | Pipercross Filter | MHD Stg2 93
itsrichierich186.50 |
06-29-2020, 10:41 AM | #228 |
Moto Lover
187
Rep 591
01-24-2021, 05:26 PM | #229 |
Rep 1,934
Wrong forum to ask. We all have the F series
10-16-2021, 11:56 AM | #231 |
das Eichhörnchen
46
Rep 279
Does anyone know if the new part number of the LSD 33-10-8-659-989 fits the N55 435i with automatic transmission?
The original 33107555607 is discontinued for years now. The only other option I see for N55 F30/32 seems to be aftermarket diff builders that use a non-oem diff (Wavetrac, Quaife etc) and you need to send them your original core (differential). |
11-12-2021, 05:56 AM | #232 | |
Rep 26
What is the impact of the slight difference in ratio other than the ~2% difference in indicated speed? Will the DME freak out and throw codes? |
11-12-2021, 10:34 AM | #233 | ||
Rep 10,376
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line |
11-12-2021, 12:17 PM | #234 |
Rep 383
According to realOEM, the 33108659989 part number is a 2.81 final drive ratio.
Also, drive shaft for the pre-vs post LCI car's are different - 435i = 1509mm, 440i = 1504mm. Axle shafts are also different part numbers between pre- and post LCI automatics. It seems like LCI made the axles common between auto/manual and manual pre-LCI, but pre-LCI auto have a unique part number. So the known issues with putting a manual diff into an automatic are driveshaft length is different, and axle shafts are different length, and some dust seals are different. Based on that known incompatibility, I believe this part number will not work for pre-LCI automatics, without additional parts being changed, or potentially custom work being done. |
Logicoeur993.50 |
09-15-2023, 07:37 PM | #235 |
ots mods mst air,wagner ic,stage1 ots tune
Rep 1
I have the 2013 n55 f30 just before launch control[tried it just made a bad smell lol]
uprated air flow for intake and intercooler,dropped plugs to 1step colder iridium,replaced v/c {leaking}and remapped ots with a carbon clean...whats peeps opinion 76k..wanna look after this girl |
02-01-2024, 03:31 PM | #236 |
Rep 496
Managed to pick up a used M perf LSD, seller said had about 40k miles on it. I'm planning to drain and fill with new fluid, but is there any other maintenance I should be aware of or consider doing? It is off the car so now would be the easiest time.
Performance Mods: Eibach Pro Kit Springs, Eibach Sway Bars, KONI SA Dampers, M Perf Rear Brakes, Dinan Free Flow Exhaust, MHD Stage 2
Retrofit: Reversing Camera, Rear PDC, Front PDC, NBT Evo |
