06-20-2022, 04:33 PM | #1 |
Rep 499
Drives: F36 440i
Broken Axle
Update: Broken axle. Not cheap but could have been much worse!
I experienced a sudden, catastrophic driveline failure on either the 1-2 or 2-3 shift at about 1/4 throttle. The noise was awful, like ball bearings in a blender. Also heard pieces of metal hitting the ground, however no fluid leaking from the transmission area under the car. I did see what looked to be gear oil on the rear control arm, so I assumed I blew up the rear end, broke an axle or drive shaft. No power to the wheels at all, the car needed to be towed. Good news: With the car in park and engine running there is no noise, so the engine seems fine. Bad news: When I shift into gear, even neutral, the awful rotating noise returns. I cannot imagine why that noise would be present with the car in neutral if the issue is behind the transmission The shop I went to (VAST Performance) said it is unlikely that my ZF 8-speed is destroyed as they regularly handle much more torque. However, if I do need a new transmission, they have not had any success coding one to work from another car, so I would need a new transmission from BMW. Cost is about $14k for the transmission + labor. Fuck! They will not be able to look at it until the end of the week at the earliest, so now I wait. My questions to you guys are: 1. Do you have an explanation for the noise I described that doesn't involve the transmission itself? Is something engaged even in neutral that would rotate a broken driveshaft for example? 2. Has anyone had success coding a used transmission from another car or know of a shop that has done this? I will update after I hear back from VAST, hopefully later this week. 2017 440i Gran Coupe RWD 48k miles BM3 Stage 2+ E50 XHP Stage 3 MPSS 265/35/19 Last edited by DV; 06-23-2022 at 05:41 PM.. |
06-20-2022, 07:47 PM | #2 | |
Rep 18
If it is the diff, grab a used one from car-part.com, its far less expensive than the dealer. If you find one with over 60k on it, it'll probably last the life of the vehicle. Further to that, unless it's in park, the transmission will free wheel in neutral slightly and will spin the broken pinion gear (assuming that's what's shattered) |
06-20-2022, 10:31 PM | #3 | |
Rep 499
Drives: F36 440i
I've been looking for an excuse to upgrade to the M-Performance rear diff and suddenly the cost doesn't seem so bad lol. Thanks for the feedback! |
06-22-2022, 12:15 PM | #4 |
Rep 7,626
If the noise is present when the driveshaft is not spinning at all, its probably trans... should be very simple to test.
If it is trans: https://www.puredrivetrainsolutions....-transmissions |
06-22-2022, 02:41 PM | #5 | |
Rep 499
Drives: F36 440i
I came across Pure transmissions the other day. I heard they can code remotely as well. I will most likely go that route if the trans needs to be replaced. Thanks for the suggestion. |
06-22-2022, 04:20 PM | #6 | |
Rep 1,597
03-30-2024, 02:24 PM | #7 |
Rep 7
Hello, did we finally find out what the fault was? I have read in several forums about this problem and today it happened to me on my 435i, from what I know and seeing several cases "luckily the axle will break and not the transmission or transfer"
Enviar comentarios |
03-30-2024, 02:52 PM | #8 |
Rep 499
Drives: F36 440i
Broken inner CV joint on the left rear axle.
No damage to the transmission or differential. Replaced the axle and we’re all good. |
03-30-2024, 04:31 PM | #9 |
Rep 7
