04-07-2024, 11:37 PM | #1 |
Rep 6
No crank after TU HPFP install
I purchased a Tu HPFP for my gen 1 B58 I installed it myself and once i went to start my car it wouldn’t Crank didn’t do anything, after a bit in trying to figure out the problem I went and put back the Stock HPFP and sadly enough It didn’t crank either what’s the issue that i’m running into ? someone please help thank you. Oh and i’m getting no fault codes only the “Drive train Malfunction” alert
04-08-2024, 02:38 AM | #2 |
Rep 119
If theres a drive train fault,then there should be a dtc.What scanner are you using?Did u remove the positive/red cable by the jump point?near the strut bar?check if thats in.Check fuses as well.
04-08-2024, 05:26 AM | #3 |
Rep 6
it’s not and actually scanner I’m using, it’s the dongle of my boot mod 3 tune and it scans no fault codes, i’ll check fuses today but i if not i might just have it towed. Yes i completely disconnected the battery but didn’t help either.
